  • No access to the intercom created in the connections panel, even though calls are signalled by push- after clicking on them, the basic application window with scenes and devices, etc. opening.
  • No access to garage door devices (barriers) that are available in the old application and www. Isn't possible to open or close doors remotely or check the status. Is necessary tocreate an intermediate VD.
  • No thermostats and control options for heating, you need to create heating zones that have less functionality than the thermostats themselves. Why a thermostat that can only be controlled via WWW (I not check HC2 on 4.610, I use 4.600)
  • No air conditioning control (cooling)
But this is not a bug to an existing feature. This is simply something you would like to have, right? Did it work like that before?
What devices are those? We would have to check these devices in API whether there were any changes between Yubii App and FIBARO App.
What devices do you have in mind? The Yubii App did offered control only of heating zones. So, I think that this is not a bug to a feature but a request
You have to be more specific. With QA/VD or a plugin available you can have support for a device. It is possible that the actual device that you use in not supported.
