Master Hc2 - hcl3 slave
Hi
its possible to have hc3 lite as a slave from hc2? When update will available?
regards
as far as I know, such feature is not planned to be implemented.
There are these option for you:
Master = HC2 with slave = HCL or another HC2
Master = HC3 with slave = another HC3 (this should be currently supported) or HC3L will be supported in next software update (version 5.080) I suppose
    Very thanks.
    I know HCL, not suport LUA scenes, but if have a hcl as a slave of hc2, and the devices from hcl are sincronize with hc2, when a create a scene LUA(hc2), the devices from hcl will there, só I can used this devices in LUA, right?
    10 hours ago, Jurassik said:
    Very thanks.
    You are welcome.
    Yes, exactly devices connected to HCL can be used in LUA scenes created at HC2.
    When you will make gateway connection between HC2 and HCL, you will see all devices in mobile app or web UI from both gateways. The devices that are physically connected to HCL will have some coloured frame arround their icons (only at web UI of HC2) - so you are able to recognize those devices at first sight.
    Another thing if you add new device to HCL (slave unit) you will have to do synchronizing manually in master unit HC2 - so you will see new devices from HCL also in HC2 web UI.
