Posting external data using curl to QuickApp method
Can anybody advice how to post using external curl data (json table) to custom QuickApp method defined n QuickApp device?
I've created device having custom method that is going to be triggered from outside by external system.
For test purposes created method shows posted data:
function QuickApp:updatecrazy(sentdata)
    self:debug("updatecrazy Invoked")
    self.debug("sentdata: "..sentdata)
    self.debug("tostring(sentdata): "..tostring(sentdata)")
Trying to POST data from outside function is triggered but data is nil, regardless of posted data json (with "args" or without).
Examples of curl and debug output:
#1
curl -X POST "https://FIBARO_HC3_ADDRESS/api/devices/489/action/updatecrazy" -H  "accept: */*" -H  "Content-Type: application/json" -H  "X-Fibaro-Version: 2" -H  "Accept-language: en" -H  "Authorization: Basic  password==" -d "{\"args\":[\"{arg1_ss:1}\",\"{arg2_ss:1}\"],\"delay\":0}" -k
[23.04.2021] [17:13:42] [DEBUG] [QUICKAPP489]: onAction: {"args":["{arg1_ss:1}","{arg2_ss:1}"],"actionName":"updatecrazy","deviceId":489}
[23.04.2021] [17:13:42] [DEBUG] [QUICKAPP489]: updatecrazy Invoked
[23.04.2021] [17:13:42] [DEBUG] [QUICKAPP489]: nil
#2
curl -X POST "https://FIBARO_HC3_ADDRESS/api/devices/489/action/updatecrazy" -H  "accept: */*" -H  "Content-Type: application/json" -H  "X-Fibaro-Version: 2" -H  "Accept-language: en" -H  "Authorization: Basic  password==" -d "{\"args\":[\"{sentdata:1}\"],\"delay\":0}" -k
[23.04.2021] [17:17:07] [DEBUG] [QUICKAPP489]: onAction: {"actionName":"updatecrazy","args":["{sentdata:1}"],"deviceId":489}
[23.04.2021] [17:17:07] [DEBUG] [QUICKAPP489]: updatecrazy Invoked
[23.04.2021] [17:17:07] [DEBUG] [QUICKAPP489]: nil
#3
curl -X POST "https://FIBARO_HC3_ADDRESS/api/devices/489/action/updatecrazy" -H  "accept: */*" -H  "Content-Type: application/json" -H  "X-Fibaro-Version: 2" -H  "Accept-language: en" -H  "Authorization: Basic  password==" -d "{\"sensor1\":0,\"sensor2\":0,\"sensor3\":0,\"sensor4\":0}" -k
[23.04.2021] [17:19:19] [DEBUG] [QUICKAPP489]: onAction: {"actionName":"updatecrazy","args":[],"deviceId":489}
[23.04.2021] [17:19:19] [DEBUG] [QUICKAPP489]: updatecrazy Invoked
[23.04.2021] [17:19:19] [DEBUG] [QUICKAPP489]: nil
#4
curl -X POST "https://FIBARO_HC3_ADDRESS/api/devices/489/action/updatecrazy" -H  "accept: */*" -H  "Content-Type: application/json" -H  "X-Fibaro-Version: 2" -H  "Accept-language: en" -H  "Authorization: Basic  password==" -d "{\"args\":[{\"sensor1\":0,\"sensor2\":0,\"sensor3\":0,\"sensor4\":0}]}" -k
[23.04.2021] [17:21:25] [DEBUG] [QUICKAPP489]: onAction: {"actionName":"updatecrazy","args":[{"sensor4":0,"sensor2":0,"sensor1":0,"sensor3":0}],"deviceId":489}
[23.04.2021] [17:21:25] [DEBUG] [QUICKAPP489]: updatecrazy Invoked
[23.04.2021] [17:21:25] [DEBUG] [QUICKAPP489]: nil
#5
curl -X POST "https://FIBARO_HC3_ADDRESS/api/devices/489/action/updatecrazy" -H  "accept: */*" -H  "Content-Type: application/json" -H  "X-Fibaro-Version: 2" -H  "Accept-language: en" -H  "Authorization: Basic  password==" -d "{\"sentdata\":[{\"sensor1\":0,\"sensor2\":0,\"sensor3\":0,\"sensor4\":0}]}" -k
[23.04.2021] [17:22:59] [DEBUG] [QUICKAPP489]: onAction: {"actionName":"updatecrazy","args":[],"deviceId":489}
[23.04.2021] [17:22:59] [DEBUG] [QUICKAPP489]: updatecrazy Invoked
[23.04.2021] [17:22:59] [DEBUG] [QUICKAPP489]: nil
It seems trigger onAction gets data only when it is posted in format having "args" like e.g.:
"args":
[{"sensor1":0,"sensor2":0,"sensor3":0,"sensor4":0}]
but sentdata variable is nill.
Should I post something different using curl or should I read another data (not sentdata variable) in order to access posted values?
Any help would be appreciated,
Regards
Mike
    Sorry all. My fault.
    self.debug instead of self:debug did the mess with my testing.
    For any who will have to manage posting do QuickApp from external sources - variable(s) value(s) shall be posted as an "args" json table, e.g.:
    "args": [
    or
    "args": [
       "delay": 0
