Fibaro Influxdb Telegraf plugin
Hi!
I have started to use the Telegraf plugin in Influxdb to pull in Fibaro device data through the http API. It looks it only pulls the real devices but not the virtual ones. Does anyone has the same problem? Any idea how to workaround it?
I checked directly the API calling a virtual devise ID and that works of course but the plugin does not pull in.
Thanks!
14 answers to this question
I use InfluxDB the other way around. I push data from HC3 to InfluxDB (v1.8)
    Thanks for the link. I have tried to use it but it looks it is more for HC3. I have HC2. Going through the code now but struggle to rewrite. I have argument error now. By any change do not you have a HC2 version?
    Yes, it is code for HC3. Sorry, I don’t use it on a HC2.
    @1forrest You can find the code for HC2 here....
    Edited by RH_Dreambox
    Similar to the HC3 code, but still getting error. Since I am using the Influxdb 2.0 the auhtentication part has to be rewritten to toke, bucket, eorg, etc as far as I know according to the new API.
    Someone else also tried v2.0, but doesn't work (indeed authentication). You have to downgrade to v1.8
    no. just add u / p
    Edited by hater
    I still want to resolve in v2 rather than downgrade. But maybe later give up and ending in 1.8:)
    As far as I know user and password not enough since the organization and token concept has been introduced in
    . Hence I rewrote the url and now it is: [DEBUG] 18:24:19: 192.168.1.124:8086/api/v2/write?org=fibaro&bucket=fibaro3&precisions=s
    And the token is also provided as a parameter in the header:  --  ["Authorization"] = "Authothorization: Token " .. deviceToken,
    Still having issue and I think this is not because of theauthentication (yet) When the function called  "sendDataToInflux(body)" then I get
    [DEBUG] 18:26:14: 2021-04-26 18:26:14.191664 [ fatal] Unknown exception: std::runtime_error: 'Invalid argument'
    My body also looks ok:
    [DEBUG] 18:26:14: Body: fibaro,sectionName=Outside,deviceID=105,roomName=Outside,deviceName=WindSpeed\ (km/h) value=2.5678057167419 1.619454374e+18
    Any suggestion what argument can cause the problem? I created a brand new bucket (fibaro3) in influx to feed tha data to.
    On 3/28/2021 at 12:09 PM, JcBorgs said:
    @claudent I do believe that the difference is what version of Influx you are running. I have two RaspBerryPi, one running InfluxDB 1.8 (32bit) and one running InfluxDb 2.0 (64bit).
    I see the exact same error messages on the InfuxDb 2.0 which is related to that this version have a different authentication system. I have so far not been able to solve that and have given up and only use the InfluxDB 1.8.
    you are not alone ?
    I will try to get some help through influxdb forum. I hope get some valuablw info bwfore I gave up:)
    I have a scene on HC2 pushing the data to influxdb. I found it
    Finally I could rewrite the HC2 code to Influxdb V2. Works fine for me. Here is the code:
    %% properties
    %% events
    %% globals
    function urlencode(str)
      if (str) then
        str = string.gsub (str, "\n", "\r\n")
        str = string.gsub (str, "([^%w %-%_%.%~])",
            function (c) return string.format ("%%%02X", string.byte(c)) end)
        str = string.gsub (str, " ", "+")
      return str
    local host = "IP" -- Host of Influxdb
    local port = "<PORT>" -- Port of Influxdb, default 8086
    local bucket = "<BUCKET>" -- Your Bucket name
    local deviceToken = "<TOKEN>" -- Token of the bucket. Must has read/write access to bucket
    local org = "<ORGANIZATION>" -- Influx Organization name
    local org_id = "<ORGANIZATION ID>" -- Influx Organization ID
    local tcpTimeout = 10 * 10000
    local httpClient = net.HTTPClient({timeout=tcpTimeout})
    function sendDataToInflux(body)
        local url = host .. ":" .. port .. "/api/v2" .."/write?" .. "org=" .. org .. "&bucket=" .. bucket
      -- .. "&precisions=ns"
    --print(url)
        local headers = {
            ["Authorization"] = "Token " .. deviceToken,
            ["Content-Type"] = "application/json",
        httpClient:request(
            url,
                options = {
                    headers = headers,
                    data = body,
                    method = "POST",
                    timeout = tcpTimeout
                success = function(response)
                    if (response.status < 200 or response.status >= 300) then
                        print(json.encode(response))
                        print("Wrong status '" .. response.status .. "' in response!")
                    else
                end,
                error = function(response)
                    print("Connection error: ")
    function saveToInflux(measurement_name, value, deviceID, deviceName, roomName, sectionName)
        local data = {
            measurement = measurement_name,
            time = os.time(os.date("*t")),
        tags = {
                deviceID = deviceID,
                deviceName = deviceName,
                roomName = roomName,
                sectionName = sectionName
            fields = {
                value = value
      local body = data.measurement
        for k, v in pairs(data.tags) do
            if v ~= nil then
                v = tostring(v)
                v = v:gsub("%s+", "\\ ")
                body = body .. (body == "" and "" or ",") .. (k .. "=" .. v)
        body = body .. " " .. "value=" .. tostring(data.fields.value)
      --.. " " .. tostring(data.time)
        print("Body: " .. body)
    function saveByDeviceID(measurement, deviceID, property)
        property = property or "value"
        local roomID = fibaro:getRoomID(deviceID)
        local room = api.get("/rooms?id="..roomID)
        local section = api.get("/sections?id="..room.sectionID)
        local value = fibaro:getValue(deviceID, property)
       saveToInflux(measurement, value, deviceID, fibaro:getName(deviceID), fibaro:getRoomNameByDeviceID(deviceID), section.name)
    -- Devices to be sent
    saveByDeviceID("fibaro3", 105) -- Provide the measurement name and the device ID
    Edited by 1forrest
    Hello, I used influxdb on HC2, HC2 has automatically push all data to influxdb.
    I'm on HC3 now, is there any step-by-step instruction for setup? Where exactly I need to put above code?
    Influxd is up&running, but what to do in HC3?
    Hi!
    The above code I put is to HC2 on v2 Influx. This should not work on HC3. You should use the one that was linked above. Here is also the link:
    The question what version of Influxdb you are using. This code works for 1.8 as far as I know. If you have v2 then you have to rewrite the authentication part since bucket, organization and token required.
