Philio PAN06 doesn't work fine in HC2 4.610
Hello!
After updating the Fibaro HC2 and HCL controllers to version 4.610, 2 Philio PAN06 modules were added to the system. In the associations of these modules, the HC2 controller has been added to groups 2 and 3. When a command is given to inputs S1 or S2, the relay is activated, but the relay status is not displayed in the interface. On version 4.600, this problem was not observed, and the module added to the system on version 4.600 continued to work normally after upgrading to 4.610.
The same issue is observed in HC3 5.070.42.
I ask for help in solving this problem.
