Satel Integra + HC3 - plugin is not working
Using the official Satel plugin for HC3, I added my control panel. After entering my access data, HC3 created 128 zones, 128 switches and 32 partitions as hidden devices.
How can this be configured and limited somehow. At the moment I can apparently see these devices, but it is completely useless to me.
Wait until the system updates itself until it will be named the same as in Satel system. It took me very long time. Then unhide only those which you use.
Hello, @Rafal100 did you solve the problem? It looks like I have a similar one
Figured out the problem. In DLOADX on ETHM-1 page, integration needs to be enabled + 7094 port needs to be used
