Matija Vizintin 0
I have HC3 and RS3 connected to venetian blinds. They are controlled wirelessly so i don't have any physical switches connected to RS3. I want to control the angle of the slats, how can i do that?
Parameter 20 is set to 0, parameter 151 is set to 2 (venetian blinds) and parameter 152 is set to 1.5s which seems fine. In the interface i have open/close and blinds level where i can adjust the height of the blinds and there is also level change that does exactly the same as open/close but the is no way to control the angle of the sluts (except manually using pause of course). I might be missing something here because it doesn't make sense that open/close and level change do the same thing. Otherwise what's the point of parameter 151 if i can't set the angle of the sluts?
Also it seems that there is no way to simulate a momentary press ex. 0.75s that would put the sluts at 90º angle to let the light in.
