Is it possible to shrink my LUA-code and use variables(HC3)?
This LUA-scen is what i can produce with my skills for now. I think sloppycode is the term for my LUA....
I converted one of many Block Scens (20 scens one for each setpoint) to LUA. With LUA-manual and reading forum i came to this solution.
I do not know if i provide needed information for getting help.
Problem 1: Is it possible to shrink the LUA?
Problem 2: I need a variable named local tempadjloc with a value that i can add to --fibaro.call(1792, 'setValue', 10+local tempadjloc)
Problem 3: I need a global variable named tempadjglo and qubinodimvalueglo to use in other scens.
PS! Before my funeral i hope to learn program QA, for now it seems that QA will be my funeral. At least a mental meltdown....
Declaration:
  conditions = { {
      id = 1828,
      isTrigger = false,
      operator = ">=",
      property = "heatingThermostatSetpoint",
      type = "device",
      value = 10
      id = 1828,
      isTrigger = true,
      operator = "<=",
      type = "device",
      value = 30
  operator = "all"
Action:
----------------------testing-----------------
print("----Test variabel----")
print(fibaro.getGlobalVariable("sovter", value))
print("SOVTER", sovter)
--tonumber(fibaro.setGlobalVariable('sovter', 20))
--tonumber(fibaro.setGlobalVariable("globtempqub1:"=r"))
local sovter = sovter
local tempqub1 = (fibaro.getValue(1828, "heatingThermostatSetpoint")+10);
print("tempqub1:", tempqub1)
----------------------all above testing-----------------
--LUA SCEN HC3
print("----Element with heatregulator 0-10v connected to qubino 0-10v dimmer----")
print("----Change value of dimmer with thermostat setpoint----")
print("----Dimmer also adjusted with variable not known for now and not working----")
--local adjustment = 50 working
--fibaro.call(1792, 'setValue', 10+local tempadjust) not working
print("ELEMENT: " , fibaro.getValue(1792, "value"));
print("SOVTHERMOSTAT: " , fibaro.getValue(1828, "heatingThermostatSetpoint"));
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 10 then;
fibaro.call(1792, 'setValue', 10)
    print("New element temp: " , fibaro.getValue(1792, "value"));
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 11 then;
fibaro.call(1792, 'setValue', 11)
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 12 then;
fibaro.call(1792, 'setValue', 12)
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 13 then;
fibaro.call(1792, 'setValue', 13)
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 14 then;
fibaro.call(1792, 'setValue', 14)
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 15 then;
fibaro.call(1792, 'setValue', 15)
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 16 then;
fibaro.call(1792, 'setValue', 16);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 17 then;
fibaro.call(1792, 'setValue', 17);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 18 then;
fibaro.call(1792, 'setValue', 18);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 19 then;
fibaro.call(1792, 'setValue', 19);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 20 then;
fibaro.call(1792, 'setValue', 20);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 21 then;
fibaro.call(1792, 'setValue', 21);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 22 then;
fibaro.call(1792, 'setValue', 22);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 23 then;
fibaro.call(1792, 'setValue', 23);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 24 then;
fibaro.call(1792, 'setValue', 24);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 25 then;
fibaro.call(1792, 'setValue', 25);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 26 then;
fibaro.call(1792, 'setValue', 26);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 27 then;
fibaro.call(1792, 'setValue', 27);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 28 then;
fibaro.call(1792, 'setValue', 28);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 29 then;
fibaro.call(1792, 'setValue', 29);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) == 30 then;
fibaro.call(1792, 'setValue', 30);
if tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) < 10 or
    tonumber(fibaro.getValue(1828, "heatingThermostatSetpoint")) > 30 then
    print("Element not adjusted, thermostats setpoint is to low or to high <10 or >30")
Declaration:
  conditions = { {
      id = 1828,
      isTrigger = false,
      operator = ">=",
      type = "device",
      value = 10
      id = 1828,
      isTrigger = true,
      operator = "<=",
      type = "device",
      value = 30
  operator = "all"
Action:
--LUA SCEN HC3
You can start with this simplification
Something like
fibaro.call(1792, 'setValue', 10+tempadjust)
should work, but I'm a bit unsure about what you want to accomplish
