andreiqu 0
Almost all my lights are from Philips HUE and I have normal switches. The problem is that all the time I need to keep the switches on to be able to control the lights from FIBARO and if I want to control the lights manually I need to turn off the switch and to turn it on again. I saw that Philips has some new modules hue wall switch, but they are not available still and I will have to open each switch at each 2 years to change the batteries.
I was thinking to change the wall switches with Walli, but I have few questions:
1. Walli Dimmer (for normal led, not Philips HUE) needs bypass also? It works well with led?
2. Will Walli Single and Double work well with Philips HUE?
3. Now I have a scene for example when there is motion in one room to open the lights (Philips HUE) at 25%. Will I be able to keep the same function with Walli just by adding a block to turn on first the light?
Thank you.
