KlyX 0
Hi guys,
I wanted to motorize and Z-waveize my blinds. As there are no z-wave "Gurtwickler", I used this how-to from siio:
That worked fine so far, but I failed to calibrate the Qubino Flush Shutter I used.
What I did:
* run the blinds as far down as possible
* set parameter 71 to 0
* set parameter 73 to 1
--> that should start calibration
--> calibration start, blinds go up
--> on top, it stops, does nothing anymore.
--> calibration does not finish
I wonder why that is the case. in the German how-to it should work exactly like that.
I also tried to play with parameter 74 (to set the time for a up or down cycle).
Well, that does not work too well, as the way up takes about 4-5 seconds longer (more weight) than down.
As far as I am aware, the Qubino can only set one single time and uses both for up and down - so this does not work either.
Any ideas on that?
Oh, and I know it is nor really related: did anyone tried the same with the Jarolift? I would like to also put the buttons back to work. But the buttons are on a circuit board on a ribbon cable, so I have no Idea, what exactly needs to go to the Qubino S1 and S2.
Best,
Christoph
