I have a Smart implant and I want it to be a rain sensor on one of the binary sensors.
I use the fist wire of binary sensor along with ground to connect to a small plate with conductive paths. The Idea is that the rain to short-circuit the paths and to breach the sensor.
The problem is that is not working... :(
If I manually short the wires, I get the breach status but no luck with the water. I don't know what I'm doing wrong. Can you help? Maybe there's a parameter I need to set?
Thanks!
R
so if you connect red to black on the sensor it works?
if so, the water you use is to clean
it's better to use something like this:
      Yes
     huh..
     I connect this sensor to Smart Implant on binary sensors?
    Hi @Razvanv ,
    KEMO rain sensor can also work nicely with smart implant:
    Advantage of the KEMO rain sensor is built in heater that can prevent unwanted freezing or wetting of the sensor surface and thus false alarms.
    2 hours ago, Razvanv said:
    • Sometimes salinity is an issue with these units, this one worked fine with filtered, bottled water, but in some instances you may have to add a bit of salt to increase the waters conduction.
