Please,
I am using this scene kindly suggested by jgab @,  which does the following:
1. the motion sensor detected movement (violated)
2. the light (Dimmer) turns on at 100%.
3. after (3 minutes) it turns off.
4. if during this period a new violation occurs, the clock will be reset.
Help I need:
1. after the set time (3 minutes) the Dimmer reduces to 30%.
2. after 5 min. it goes out.
3. but if there is a new movement it goes back to the beginning of the Scene, that is, to 100% and starts all over again.
if anyone can help, it would be very important to me.
Thank you very much.
Original scene
local light=23                 -- ID light (Dimmer)
local motion=26            -- ID motion sensor
local maxTime = 1*180   -- time max motion safet
local sleepTime = 5
function loopUntil(fun,cont,secs)
local function loop()
if not fun() then
fibaro.setTimeout(1000*secs,loop)
else
if cont then cont()
fibaro.call(light, 'setValue'99)   --fibaro.call (light,"turnOn")
fibaro.debug("Luzes Dimmer On")
local safeTime = 0
loopUntil(
 function()                                     -- Loop function
  if safeTime >= maxTime then return true end
  safeTime=safeTime+sleepTime                   -- Timer SEGURO
  fibaro.debug("Contando Tempo Seguro",safeTime,maxTime)
  if fibaro.getValue(motion,'value'then --> '0' then -- motion violado
     safeTime=0       -- reset safeTime
     fibaro.debug("Reset", safeTime)
 end,
 function()  -- Things to do after the loop ends
 fibaro.call(light,"turnOff")
fibaro.debug ("Luzes Dimmer Off")
 end,
 sleepTime
This could work
    17 hours ago, jgab said:
    This could work
    jgab@,
    again helped me a lot, thanks for your attention and your time ..... working perfectly .... thanks
    jgab @,
    if i use this scene on an HC2 control panel, you could inform me of the necessary adjustments to work, thanks.
