new scene not visible in Yubii app
Hi All,
 I need help in figuring out why all new HC2 scenes are not visible in the new Yubbi app, even if they are visible in the old HC2 Fibaro App. It seems that all the old scenes before the advent of Yubii are available in Yubii but the new ones created aren't.
The scene are referring to are LUA scenes.
The same problem occurs with new sections and rooms.
Do I miss anything?
thanks!
@MaxT, If you use admin type account then in favorites tap on HC name on top and choose your HC. That should download new scenes and rooms.
In case you have user type account, then ask admin to give you permission and then do as I wrote above.
    Thanks, that was the problem, I was loggin in to the app with with a simple user. I gave all the permission and now the scenes and rooms are updated.
    Thanks!
