Header in Websocket
Trying to achive something like this python line in a QA.
I connect, send commands etc but cannot find how to include the "header"
asyncio.run(client.subscribe(query=query, headers={'Authorization': "d1007ead2dc84a2b82f0de19451c5fb22112f7ae11d19bf2bedb224a003ff74a"}, handle=print_handle))
Should it go into the connect or into the send command? (From the API (
) it says it should be included in every request. (and I have it working in a http request (where it is not streaming data)
Below suggestion (with errors)
function QuickApp:onInit()
    local url = self:getVariable("SubscriptionURL")
    self.sock = net.WebSocketClientTls()
    self.sock:addEventListener("connected", function() self:handleConnected() end)
    self.sock:addEventListener("disconnected", function() self:handleDisconnected() end)
    self.sock:addEventListener("error", function(error) self:handleError(error) end)
    self.sock:addEventListener("dataReceived", function(data) self:handleDataReceived(data) end)
    self.sock:connect(url, headers={'Authorization': \"Bearer -Hti3bM2BLhGx2XxRAqvzV7cDEg\"}")
    self:debug("onInit")
normally you have to create wrapper for that, like GraphQL or JSON RPC is doing, to be able to send extra info like headers.
Here some
Fibaro is using for their Intercom JSON RPC over WebSockets, which in principle build the necessary info and send it right after sock:connect.
So you might try something like:
