Danger! You stepped on landmine.... sorry, on "set lights level"
Guest cuprum
Yeah, exactly the same feeling, as you hear the little "klick" and know, that the next step will release the trigger.... In Yubii app (1.12) and HC2 (if it's relevant).
The ROOMS-Whole house screen and attempt to scroll screen little bit down. When the finger touches screen somewhere near "summary"... around 2 lines away/above from "Set lights level" slider, then there is a little "click" and You will see, that the "Set lights level" slider sticks to finger (will follow the left/right movement of finger, touching screen ~2cm ahead of slider - have big-screen-phone). Yeah, and You know, the release of screen will detonate - all light in house explosion.
And sorry, this happens with me 3th time just now. First time i did not understood, what exactly causes the all lights, second time had time to see the "sticky slider" and third time... even clearly avoiding from nearby of the slider triggers it ;(
mmmh just practice a bit more!
Me with my oversized fingers operate in one tip four devices, hahaahha
Now I cabn scroll without operating something.
Succes,
//Sjakie
