Very bad performance in Samsung Galaxy Tab A 10.1" 2016
The performance on this tablet is very bad, it constantly shuts down, it takes a long time to change room, it is impossible to open a QA... Do you know what is the reason? does anyone else have this problem?
Edited by antoniopll
  • antoniopll changed the title to Very bad performance in Samsung Galaxy Tab A 10.1" 2016
I have the same behavior as the app around here, check if offline login you get a better result. In contact with the support they informed me that it may be a matter of communication with the servers due to latency.
    Thanks @MarcosP I have tried it by logging offline, and I have the same problem. I have put android 11 lineage os on the tablet in case it was a problem with the OS and I have the same situation
    • 2 months later...
    I also experience unusable behaviour on 10"android tablet running Rockchip RX30. It is unusable even in local mode.
