simple scene in LUA for automating garage lights
I'm a beginner and I would like some help with a LUA scene to switch on garage lights when garage door sensor is tripped and it automatically switch them off after 5 minutes(timeout) after the door sensor is not tripped anymore(door closed).I searched the forum and found very elaborated(complex) solutions like Very smart lights  or Advanced llighting control etc.. but they are way more than I need and I didn't manage to configure them.. not have the knowledge
I do not need lux settings(night or day)
Can someone please help me with the code?
Thank you
6 answers to this question
    I put this code:
    %% autostart
    %% properties
    520 value
    569 value
    local light=520             -- ID light (Dimmer)
      local motion=569            -- ID motion sensor
      local maxTime  = 1*60      -- time max motion safety
      local dimTime  = 3*60      -- time to dim
      local dimValue = 100        -- value to dim
      local sleepTime = 5
      function loopUntil(fun,cont,secs)
        local function loop()
          if not fun() then
            fibaro.setTimeout(1000*secs,loop)
          else
            if cont then cont()
      fibaro.call(light, 'setValue', 100)   --fibaro.call (light,"turnOn")
      fibaro.debug("Luzes Dimmer On")
      local safeTime = 0
      local dimmed = false
      loopUntil(
        function()                                     -- Loop function
          if safeTime >= maxTime then return true end
          safeTime=safeTime+sleepTime                   -- Timer SEGURO
          fibaro.debug("Contando Tempo Seguro",safeTime,maxTime)
          if safeTime >= dimTime and not dimmed then
            fibaro.call(light,"setValue",dimValue)
            dimmed = true
          if fibaro.getValue(motion,'value') then --> '0' then -- motion violado
            safeTime=0       -- reset safeTime
            dimmed = false
            fibaro.call(light,"setValue",100)
            fibaro.debug("Reset", safeTime)
        end,
        function()  -- Things to do after the loop ends
          fibaro.call(light,"turnOff")
          fibaro.debug ("Luzes Dimmer Off")
        end,
        sleepTime
    but I got error [DEBUG] 22:25:00: 2021-05-31 22:25:00.771722 [ fatal] Unknown exception: /opt/fibaro/scenes/56.lua:26: Assertion failed: Expected string
    I do not need deem because I have Fibaro switch, not dimmer for lights..
    Sorry, I didn't see that you had an HC2. This code runs on the. HC3.
    OK.. do you have any sugestion for how to acomplish this on my HC2? (not with dimmer,but simple switch for lights)
    Thank you
    %% properties
    XXX value
    %% events
    %% globals
    if (fibaro:countScenes()>1) then
    -- fibaro:debug("abort")
    fibaro:abort();
    if (tonumber(fibaro:getValue(XXX, "value")) > 0)  then
    local timer = 300; -- time in secs
    fibaro:call(XXY, "turnOn");
    repeat
    fibaro:sleep(1000);
    timer = timer - 1
    timer=300 -- time in secs
    until (timer<1)
    fibaro:call(XXY, "turnOff");
    Try this where
    XXX = motion sensor ID
    XXY = light ID
    I think it's working nice..Will test more in depth tomorrow
    Many thanks for the help !
    Edited by emariu
