Grotesmurf 0
I use the scene below (found on the web) for irrigating the garden. It works great, but i do miss the option to enable/disable (or set) the days of weeks on which this scene has to run. now it runs every day, and i don't want that.
I am not able to add this functionality, so can somebody help me with this? i would like to be able to set a day of week on or off. for example:
monday=1
tuesday=0
wednesday=1
thursday=1
friday=0
etc
thanks in advance..
Ronny
this is the scene:
%% autostart
%% properties
%% events
%% globals
local irrigators = {178, 190, 186, 44}; --sprinklers
local startTime = {"22:00"}; --spriklers start time
-- org: local startTime = {"23:00", "12:17", "20:26", "21:00"}; --spriklers start time
local sectionTime = 30*60*1000; -- 75 minutes by default
local timeModification = 1; -- might be for example 1.5 - when temperature is high
local temperatureSteps ={25, 30}; --25 and 30 degree as thesholds for modifying sprinkling time
local humiditySteps = {50,60}; -- 40% and 70% of humidity as threshlodls for modifying springling time
local modificationStep = 0.25; --25% of modification time for each step
local criticalHumidity = 30;
-- org: local rainDetector = 64;
local rainDetector = 0;
local temperature;
local humidity;
fibaro:setGlobal("StartTimeSprinkler", '22:00')
function localTime()
local localTime = currentDate.day .. "/" .. currentDate.month .. "/" .. currentDate.year .. " " .. string.format("%02d", currentDate.hour) .. ":".. string.format("%02d", currentDate.min) .. ":".. string.format("%02d", currentDate.sec) .. ": "
return localTime
function isRaining()
-- org: if(tonumber(fibaro:getValue(rainDetector, "value")) > 0) then
if(rainDetector > 0) then
return true;
else
return false;
function timeModify()
local modification = 1;
-- temperature modification
for i in pairs(temperatureSteps) do
if(temperature >= temperatureSteps[i]) then
modification = modification + modificationStep;
-- humidity modification
for i in pairs(humiditySteps) do
if(humidity <= humiditySteps[i]) then
fibaro:debug(localTime() .. "Sprinkler time modified by: " .. modification);
return modification;
function sprinkling()
fibaro:debug(localTime() .. "Start sprinkling.");
for i in pairs(irrigators) do
fibaro:debug(localTime() .. "Section " .. i .. " starts. Sprinkling for " ..sectionTime *timeModification/60000 .. " minutes");
fibaro:call(irrigators[i], "turnOn");
fibaro:sleep(sectionTime * timeModification);
--fibaro:sleep(2000); --for debug purposes (disable line above, enable this line)
fibaro:call(irrigators[i], "turnOff");
fibaro:debug(localTime() .. "Section " .. i .. " stops.");
fibaro:debug(localTime() .. "Stop sprinkling.");
return true;
function mainLoop()
temperature = tonumber(fibaro:getValue(3, "Temperature"));
humidity = tonumber(fibaro:getValue(3, "Humidity"));
fibaro:debug(localTime() .. "Current weather contition: temperature - ".. temperature .. " degree, humidity - " .. humidity .."%");
timeModification = timeModify();
sprinkling();
---------- Loop
if (startSource["type"] == "autostart") then
fibaro:debug(localTime() .. "Scene started automatically");
while true do
Time = string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min)
for i in pairs(startTime) do
if (Time == startTime[i]) then
if(isRaining() == false) then
fibaro:debug(localTime() .. "Sprinklers start automatically (no rain).");
mainLoop()
else
if (humidity <= criticalHumidity) then
fibaro:debug(localTime() .. "Sprinklers start automatically (raining, low humidity).");
mainLoop()
fibaro:sleep(1000);
elseif(startSource["type"] == "other") then
fibaro:debug(localTime() .. "Sprinklers start manually.");
mainLoop()
