Hello, I observed that in update 4.601 Beta there was specified the support for the Steinel devices:
- Support for Steinel IS 140-2 version 1.0.
- Support for Steinel L810 LED iHF version 1.1.
And then, starting with version 4.610 there is specified the above features were not included.
Meanwhile, the 620 version was released.
Can you please ley us know when you are going to add support the Steinel devices ? I assume there was a high number of requests since you have considered these features.
Thanks!
Hi, Steinel IS 140-2 what problem do you have?
works for me on HC2 since 2018 and HC3 since 2021!
Just add and see what happens for  Steinel L810 LED iHF?
//Sjakie
error
Edited by Twannie
  • 3 weeks later...
//Sjakie
Hi @Sjakie, how is the LUX measurement of the IS 140-2
If you ask my opinion bad, nor relayable at all.
He hangs several times after 1 year proper functioning.
It started with opening curtains in the middle of the night he jumped without any reason from 2 to 500 lux
One sensor hangs already 2 years on 2000 lux 24/24.
Now my curtains opens/ closes on sunset/sunrise with comensation for clouds
//Sjakie
//Sjakie
Ok I will not buy one …
bedankt!
  • 5 months later...
//Sjakie
can you tell me which parameter you have? And you used scenes for Steinel is 140-2?
Sorry, I cant tell anymore my HC3 is boxed at the moment.
//Sjakie
  • 2 years later...
I also keep having problems with the Steinel IS 140-2, after a few months no movements are detected anymore. disconnecting power is then the only option.
  • 2 months later...
I had previously made a test setup with my Steinel IS 140-2 and it worked.
Movement, Lux and Relay control came in on HC3.
Now I want to install it for permanent use. I no longer detect any movement.
I already removed it and added it again, but it turned out to be no solution.
