Guest Zooitje
I have a HomeWizard Energy P1 device connected to my electric meter.
This device has al local api that does not require authentication.
There are two api calls:
http://<ip-address>/api/v1/data
and
http://<ip-address>/api/v1/telegram
http://<ip-address>/api/v1/data gives u the following response:
While http://<ip-address>/api/v1/telegram returns the native P1 response.
I created a scene wher I want to read the P1 device but with no luck.
My code looks like this:
function process(response)
local http = net.HTTPClient();
http:request("http://192.168.178.61/api/v1/data",
{ options = {method = "GET"},
success = process,
error = error });
if (response ~= nil) then
fibaro:debug(response.data);
When I run the scene, nothing happens. The response is nil.
If I change data into telegram, I do get a response with the correct data but it is NOT the data that I want.
Can anyone tell me why the response is nil when using: http://<ip-address>/api/v1/data
4 answers to this question
