Piotr Bojko 28
I want to revert control of one othe outputs of smart implan. I have setup a local protection for both outputs. Inputs are connected to the gates reed switches an outputs are connected to to the gate controls. One output handles a START-STOP-START control and one handles a LOCK function of the gate. This works really well.
However I would like to revert the state of one output (OUT1) of the implant. I would like to have ON state of the output1 to be low/open. Currently this is reversed.
I have tried to set parameter 154 to 1 (defaults to 0) but this has no effect - probably because this param works only with local protection off and regarding the state of the connected input1.
Any ideas? I don't want to revert the state in the hub.
