json problem
I have decoded a response to json table and i can fetch almost all key except one which has a '-' in the key name.
Its "x-token" and i always get attempt to perform arithmetic on field 'x' (a nil value)
So the '-' is messing up the json key value.
Any idea what i can do?
10 answers to this question
It's probably not a json problem...
Can you share the code how you fetch the keys?
    Hi jgab,
    This is the response:
    /monthly_2021_06/image.png.aebf4858b0a60e90106a3ebf3d701b2b.png" />
    And if i use
    local data = json.decode(resp.data);
    local resp = data.object_result.roleName
    then resp is "User"
    but if i use
    local resp = data.object_result.x-token
    then i get the error message.
    BR
    14 hours ago, 747 said:
    Hi jgab,
    And if i use
    then resp is "User"
    but if i use
    BR
    You can’t use .x-token as x-token is not a valid Lua identifier.
    Use
    The same goes if you have keys in local language - like åäö...
    Ahh ok. Thanks!
    Will try it.
    BR
    Hi jgab and thanks for that solution!
    That part is working fine now but the next request returns a table with 2 keyvalues..
    Im not sure how to parse that but maybe you know:
    /monthly_2021_06/image.png.055768a6364d5273781e07b8bfc23bc3.png" />
    I can iterate using:
    for i = 1, #resp.object_result do
                  for k,v in pairs(resp.object_result[i]) do
                        print("Key: "..k.. " value "..v)
    But if would like to get the value of "Power" i need to iterate first to get value of "code" and check that is is "Power", then in the next iteration i need save the value presented as "value" (0 in this case).
    Im not sure how to fetch the value directly when i find that the code is "Power"?
    BR
    Edited by 747
    Please disregard the last screenshot. Seems i cant remove it..
    So, it's an array of items so you need to search for the code.
    Thanks alot jgab!
    BR
    Hi again..
    I almost have it working now.
    Just need to control on and off on my poolheater but cant get that to work.
    The curl cmd that people seems to get working is the following;´:
    curl -s -H "Content-Type: application/json; charset=utf-8" \
    -H "x-token: $token" \
    -d '{"param":[{"device_code":"'$device'","protocol_code":"power","value":"'$1'"}]}' \
    -X POST $cloudurl/app/device/control.json
    And with lua i have tried with this json body:
    data = json.encode({
        ["device_code"] = tostring(devCode),
        ["protocol_code"] = "Power",
        ["value"] = "1"
    Response is:
    /monthly_2021_06/image.png.aea91e65285ece526dce1e33c7d0e113.png" />
    I dont know how to translate the curl cmd to http request..
    BR
    Edited by 747
    Try
    Ahh, perfect!
    Tack!
