is that right, that new Secret Variable for QA I can set once, on creation only?
There is no EDIT (pencil) button for secret variables.
I would expect that Edit is possible, but without option to check current value.
So it looks as a bug.
/monthly_2021_06/image.png.18d436eb631c3fde80f5a0fe8defdfd4.png" />
works as designed, remove and create new, from api will be nit visble too
    Thank you for replay.
    But I would suggest to consider more normal behavior. When I program QA for community, I would add password field for access (ex. external API or device) - just to make it easy to users to enter the pass. It shall be secret to not allow others to check. For example user enter password and his installer is not able to see it... (but installer will easily access and check it via LUA).
    Current approach is hard to use, will be complicated for users who just download and install QA. Or developers will just ignore and skip that feature.
    Option to reenter the pass shall not affect your protection from API etc.
    Edited by Albert
