hello is this device working now Qubino 3-phase meter on beta
this have ben workin a long time?
you can update the firmware on qubino 3 fas if it has a firmware not working.
just ask qubino to send you the neded firmware
    Ok i try tjis ty for help
    Well I don't agree with that.....
    Yes you can include/add a Qubino 3 Phase meeter to the HC3. But it does not show the correct data, some datapoint are missing etc etc. This is regardless of what FW you are using in the Qubino meter.
    what are you missing? i have 2 off this an seams to get correct data,  i got a custom firmware from qubino after tested some different versions BUT thy sent out a new one some weeks ago that is for when fibaro updates the nex firmware, then the one im using wont work anymore.
    In current beta supprort for CC Meter was greatly improved, even for non-template devices.
    As for Qubino, we are working on a new template for 3Phase meter in all revisions.
    • 4 months later...
    Hello, m.roszak
    I've got one questions about the template, is this already fixed, and if how can I see the logging of used power(should be visible in advanced).
