pmdsaude 0
Hi guys,
I did some math to find out if the supports the operation of these 3 LED lamps together.
Each ceiling light works at AC 220v/12W, so converting the 36 watt from all 3 lights in Amperes gives less than 1A. Correct me if i'm wrong.
The Single Switch 2 supports 6A so will work without any problem.
I use 3 of this lights:
Thanks and regards.
Edited by pmdsaude1 answer to this question
