Lights on/off or dim
Ik have lights outside with dimmer. Ik will if it's sunset the lights go on 20% en else if it's daylight the lights go off. This part i have is working.
I have a motion sensor and if there is motion it set a timer and the time part is also working.
But the part i don't get working is, if there is motion the dim level must go to 90% and is the timer is 0 the lights must go to 20% or off. If the lights are 20% then go to 90% and back to 20%. And if the lights are off the lights got to 90% and back to off.
This is what i have got so far.
%% properties
767 value
%% events
%% globals
-- Zet kleuren voor debug
function Info(color, message)
  fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span"))
-- Buiten temperatuur
local BuitenTemp = tonumber(api.get('/weather')['Temperature'])
Info("white", "Buitentemperatuur is ".. BuitenTemp.." °C")
-- Tijd
Huidige = os.date("%H:%M", os.time())
HuidigeTijd = os.date("*t")
Volledige_Datum = os.date("%A %d %B %Y")
-- wis debug screen
-- api.delete("/scenes/"..__fibaroSceneId.."/debugMessages")
-- globals voor deze scene zijn
--    Buiten_Dimmer == Aan of Uit
--    Buiten_Timer  == aantal minuten
-- Apparaten en locals
local Lamp1 = 764 -- buiten lamp muur woning
local Beweging = 767 -- Bewegings melder buiten
local DagNacht = fibaro:getGlobalValue("H_DagNacht")
local Timer = fibaro:getGlobalValue("Buiten_timer")
local Dimmer1 = fibaro:getValue(764, "value")
-- Buiten lampen savonds aan
  if Huidige >= "16:00" and Huidige <= "22:45" then
  if DagNacht == "Nacht" then
    fibaro:call(Lamp1, "setValue", "20")
-- Buiten lampen smorgens aan
  if Huidige >= "06:00" and Huidige <= "09:00" then
-- Lampen automatisch uit
if Huidige == "23:45" then
    fibaro:call(764, "turnOff")
if DagNacht == "Dag" then
-- Beweging lampen aan of uit
if (tonumber(fibaro:getValue(Beweging, "value")) > 0 ) then
  fibaro:setGlobal("Buiten_timer", "6")
   Info("Green", "Lampen aan of dimniveau verhogen")
   Dimmer1 = Dimmer1 +50
if tonumber(Timer) <= 0
      then
      Info("Green", "Lampen terug in oude staat")
    Dimmer1 = Dimmer1 - 50
-- Timer
  i = Timer
    repeat
       --fibaro:debug(i)
         i = i - 1
         until i < tonumber(Timer)
         fibaro:setGlobal("Buiten_timer", i)
    Info("Green", "Nog "..i.." minuten te gaan")
-- Debug info
Info("red", "  het is nu "..DagNacht)
Info("Yellow", " Vandaag is het ".. (Volledige_Datum))
Info("Yellow", " Dimniveau is "..fibaro:getValue(Lamp1, "value").." %")
Edited by Reinhold
