A.Lurie 0
Hi i'm trying to build a scene which allow me easily change to ring color for all my walli switches and dimmers (it's annoying its not build in functionality btw
). For this im using `callGroupAction` with filters. First i was trying to use integer representation of the color (as it is implemented in rest API) but it doesn't work at all.
I've noticed it works using english name of the color, and im quite ok with that but... In this case if you make a typo (set non existing color name) HC2 stop responding and installer app also send push message with information about HC2 issue. Only i can do in this case is unplug power supply and restart HC2 this way what's not that safe i guess
Edited by A.Lurie0 answers to this question
