HC3 - TTS on Alexa?
Pablo_Supreme
I bought for myself a HC3. It's working good for this what I need it.
Unfortunately I came across a problem that I cannot solve by myself - how to use Alexas Text-To-Speach function on HC3. On this side
I found a great tutorial how to do it on HC2. On HC3 the LUA changed and I'm lost.
Does somebody did this on HC3? Or is somebody able to translate the HC2 Lua to HC3 Lua?
Thanks in advance for help.
Cheers
Pawel
Edited by Pablo_Supreme
one sentence was missing
9 answers to this question
Hallo Pablo, i have a working QA for HC3. It´s run with the webserver and php-skript from this Homepage:
Gruß Sven
  • Hi @SvenG.
    thanks for this - now I just need to make it work with my configuration 🤣
    and I did:
    • from the tutorial on iqhaus.de (link above) the php-script - it's running
    • Import the QA into my HC3
    • I got a generic virtual device with the name "SpeakME_reserve"
    • changed the IP address on tab "variables" to the one I have the php-script running
    • on tab "edit&preview" => "edit" in line 23 I changed the code "local url = "http://".. ipAddress .. "/alexa_tts/alexa.php?device_name=reserve&text_tts=" .. params" to the one where my php-script is running and changed the device name. Now it looks like this for my Alexa in the Bedroom "local url = "http://".. ipAddress .. "/alexa.php?device_name=schlafzimmer&text_tts=" .. params"
    • changed in line 49 the text (just to test if I'm right) to "mein eigener Text"
    and it works 😇 - thanks a lot - You are the best 😎
    Cheers
    Pawel
  • @SvenG.
    Did You manage to use a Variable as Text? e.g. I put the temperature of the bedroom temperature sensor as variable "temp_bedroom". Can I get Alexa to say "The temperature in the bedroom is ... (temp_bedroom)"?
    hallo Pablo_Supreme my english is very bad...u can tell me the quetions in german?
  • Hi @SvenG.
    kann ich natürlich machen (wohne auch in Deutschland). Ich habe das auf Englisch gemacht damit auch andere davon profitieren.
    Meine Frage war - gibt es eine Möglichkeit das ein variabler Text ausgegeben wird? z.B. das ich irgendwie die Temperatur von meinem Temperatursensor im Schlafzimmer ablese und wenn Die über einen bestimmten Wert kommt das Alexa sagt "Die Temperatur im Schlafzimmer ist gerade ... (globalVariable) - schließe die fenster".
    Das oben schreibst du in ein Lua-Skript...bei mir ist das in einer Szene für die Kaffeemaschine
    du kannst natürlich in die Variable "local push_text =" übergeben was du möchtest
    wäre natürlich klasse, wenn du für andere eine Anleitung machen könntest und das viele nutzen können
    Edited by SvenG.
    Seit heute morgen geht bei mir der Script nicht - wenn ich die alexa.php Seite aufrufen will dann bekomme ich eine Ansicht als ob ich das Script auf GitHub sehen würde und leider nicht die Liste aller Alexas bei mir - hat jemand eine Idee was passiert ist? Oder haben das alle jetzt so?
    Ich dachte es liegt vielleicht an meinem WebServer aber das ist nicht das Problem da ich das auf 3 verschiedenen getestet habe schon heute und auf allen bekomme ich dasselbe.
    @Pablo_Supreme I implemented the same on my HC3 some minutes ago and it works perfect.
    In the iQhaus tutorial they said that the cookies.txt needs to be downloaded again every few weeks and replaced on your PHP server.
    Already tried?
    Edited by Kiamer
    Or login your dekstop machine to the
     website, if it is in the same local IP range.
    I made the TTS part into a global variable.
    So i only need to add 2 lines in the action part of any scene where i want alexa to speak,
    fibaro.setGlobalVariable('globalTest', 'Opening%20left%20shade')
    fibaro.callUI(224, 'onReleased', 'btnSpeak')
    Anyway it is a work in progres :) (in the QA there are 2 variable's - for now only the IP entry is used)
    Ah, and 2 lines of simple php ofcourse. Change the path of the script.
    Edited by ppeterr
