Device - timer VD Fibaro
Hi, Can anyoneone help me with a VD in fibaro? I am beginner in LUA.
I made a virtual device in Fibaro HC2 to turn the device on or off -  timer. VD  works but there is one problem.
 I would like to turn off the device and stop the countdown after pressing the button STOP - NULL when the device is started with the button " Run device" . Turnf off device is ok but coundown still counts even after pressing button STOP - NULL. The countdown is running in label " Remaing time"
I would like it to reset and stop the countdown in label "Remaing time".
 VD attached in the annex.
Than you.
Isn't the while-do loop in the [Run Device] script still running, even though you have pressed the [STOP] button?  It looks to me that the [run Device] loop just keeps going as it doesn't 'know' that the [STOP] button has been pressed.
Maybe you could use a Global Variable to maintain state outside of the VD, that the while-do loop could keep an eye on and break out if rTime is set to zero?
