After updating the new beta version ,i added a new Remotec IR extender and inserted parameter 25 to start learning but at the end it didn't work.
Note: all the Remotec devices before the update works fine but the problem occurs when you add a new Remotec after the update.
I suggest you try to unplug the plug again the Remotec ZXT600, because I had similar issue even with previous HC3 firmware : the ZXT600 didn't respond to parameters change right after inclusion.
    Tried Everything removing it and adding it again ,resetting the device ,the only solution worked for me is to downgrade the version .
    • 5 months later...
    Hi Mutaz,
    I have 4 ZXT600 and 3 of them are unable to learn. When I send a parameter 25, the ZXT600 led would flash green once and red twice immediately. May I know which version of ZXT600 are you using and how to downgrade?
