Please help.
I am using Z-Wave 3 now.
My first device from Steinel, needs to be updated (I have the files).
Can anyone help me with a guide.
I can't see how to upload a file and subsequently select it, to update my devices
attach the files you have, and i will make some screenshots how to run update
    Thanks. I have attached the newest firmware for Matrix ZDB
    you will be not able to update Steinel with Matrix firmware. Or is there other reason why you uplaoded different firmware? My intention was to check, if the Steinel firmware is ok.
    The procedure is always the same, go to 16. Zwave, click on "Upload file" button (from the device you wish to update),
    select target 0 (unless otherwise specified by the manufacturer), select the firmware file and click on "start update".
    /monthly_2021_07/image.png.47f6273fa410107663372eebabaf6917.png" />
    That might not work in some cases, e.g. i got issues with S0 included devices.
    Of course it make sense to reconfigure device after firmware update.
    Edited by tinman
    Thank you.
    My mistake with the wrong file.
    I have many devices that I would update this way.
    That was exactly what I needed.
    Now I'm looking forward to see Fibaro making a migration of existing installations, to the new Z-Wave 3.
    Current customers will be bored of having to start all over again on integrating all their devices.
    Edited by Integrator Logic Home
