FGRM-222 loses positioning
Davs
Good afternoon, Let's see if you can give me a hand because I'm going crazy.
I have several blinds with FGRM-222 actuators to control them, and I also have toggle buttons installed to be able to raise and lower manually. The values in controller are: 0 closed, 9 sleep summer, 30 nap, 50 parasol, 100 open, 240 stop.
If I do not use the physical buttons, when selecting any value in controller , it works without problem.
The problem is that if I use the physical buttons, it seems that the blind loses its position / calibration, and if I then select a value in controller, the value does not correspond to what is desired (the summer sleep position, for example, remains open at 50 %, instead of 9%)
I have to recalibrate the blind (with param .. 29) and then the eedomus values go well, until I use the buttons again.
Sometimes if I have the blind down and I press the up (physical) button and leave it, the blind goes up completely and thenit  does a kind of self-calibration, because once raised, it goes down alone and goes back up alone.
The parameters of the blinds:
10 = 1 - Roller Blind Mode, with positioning
14 = 1 - Toggle switches
18 = 10 Motor operation detection
44 = 0 - Self-measurement inactive.
I have several blinds and it happens to me in all ...
any idea? thanks in advance.
Edited by Davs
