twanve 18
Is there a possibility to switch the Local Protection slider from On to Off with Lua code...? (see picture)
And the possibility for get value from this slider with lua "if slider_x is true then ....."
I have a gate opener with a button on the inside of the pad for opening the gate. I will to disable this button at night of when I live the house.
When you set the slider manually to On, the button are disables. But to this manual is no option:-)
You will when you start scene "Live house". this slider go to On and when you come home slider go's to Off.
I try with Block Scene, but this button is not visible
Somebody any idea....
