Symbiot78 2
Hi
I'm trying to figure out how to use some response data. I want to convert specific data to a variable.
I request data from a URL
I get the below response.
I want to get the following into a variable:
shadeId
position
so the result is that I know that shadeId 50173 is in position1:65483
{"shadeIds":[50173,40999,7342],"shadeData":[{"id":50173,"type":55,"capabilities":4,"batteryKind":1,"smartPowerSupply":{"status":0,"id":0,"port":0},"batteryStatus":0,"batteryStrength":0,"roomId":59205,"firmware":{"revision":1,"subRevision":8,"build":1944},"name":"U3R1ZSBMYW1lbA==","signalStrength":0,"motor":{"revision":50,"subRevision":48,"build":11826},"positions":{"posKind1":1,"position1":65483,"posKind2":3,"position2":400},"groupId":11973},{"id":40999,"type":54,"capabilities":4,"batteryKind":1,"smartPowerSupply":{"status":0,"id":0,"port":0},"batteryStatus":0,"batteryStrength":0,"roomId":36806,"firmware":{"revision":1,"subRevision":8,"build":1944},"name":"S0EgQWxrb3Zl","signalStrength":0,"groupId":6735,"motor":{"revision":50,"subRevision":48,"build":11826},"positions":{"posKind1":1,"position1":65534,"posKind2":3,"position2":58360}},{"id":7342,"type":55,"capabilities":4,"batteryKind":1,"smartPowerSupply":{"status":0,"id":0,"port":0},"batteryStatus":0,"batteryStrength":0,"roomId":36806,"firmware":{"revision":1,"subRevision":8,"build":1944},"name":"S0EgTlkgVsOmZw==","positions":{"posKind1":1,"position1":65535,"posKind2":3,"position2":20},"signalStrength":4,"groupId":45116,"motor":{"revision":50,"subRevision":48,"build":11826}}]}
The code I run in a scene is:
17 answers to this question
