Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Important Notices:
The following software update removes energy data collected during the use of version 5.071 beta due to a changed strategy for handling reports.
For all Z-Wave devices which feature meter capabilities (power, energy, gas, water, etc.) soft-reconfiguration procedure is required due to improvements in support of those device types.
Update 5.072 includes a new version of the Z-Wave software (called Z-Wave 3.0). This version features expanded default device support, the ability to add products using Smart Start technology and many other changes. Please note that this is a beta version and its compatibility will be developed with further updates - not all Z-Wave devices are fully supported.
ATTENTION - installing version 5.072 does not automatically change the existing Z-Wave 2.0 software to 3.0. In order to run version 3.0, it is necessary to restore the gateway to factory settings, requiring the system to be configured from scratch. In future updates we will work on extended device support and provide a mechanism to migrate your current system configuration to the new Z-Wave engine.
Main features:
1. Z-Wave Software 3.0
Extended compatibility of Z-Wave devices (more devices, additional features).
2. Yubii Ecosystem (Home Center 3 & Yubii Home)*
Support for configuring device parameters.
Redesigned configuration wizard.
3. Energy Panel
New Savings tab and Panel Settings window.
What's new:
Backup
Warning before restoring a backup contains the Z-Wave engine version when it differs.
Space for cloud backups is increased by 25MB on master HC3 for each connected gateway.
Climate
Wider range of temperature to be used in schedules.
Dashboard
Correct scrollbar in the main menu.
Live refreshing the value on the right device control panel.
Devices
Possibility to upload the parameters template to Z-Wave device from .json file (ZW 3.0).
Possibility to delete parameters template which overrides the official template (ZW 3.0).
Extended list of official templates for Z-Wave devices (ZW 3.0).
Support of scale and unit for Z-Wave devices in parameters templates (ZW 3.0).
Console log of detecting the Z-Wave device and starting the adding process (ZW 3.0).
New mechanism of devices calibration (ZW 3.0).
Restoring the default device icon if uploaded icon no longer exists.
Changes in energy data component on device advanced tab.
Availability of configuration parameters based on device interfaces.
Possibility of setting the virtual power metering and using it in energy panel.
Support for Heatit Z-Smoke Battery version 4.1/4.2.
Support for Qubino 3-Phase Smart Meter.
Elero*
Dedicated section in the main settings menu for Elero and Nice.
Energy
Panel Settings window which allows to configure more options related to costs.
Possibility to choose the billing period by setting its length and start date.
Possibility to set up the tariff by choosing the currency, main rate and additional rates.
Possibility to set up the installation cost and installation date.
New Savings tab including summary of consumption and energy balance in time.
Toggle switch on General and Savings tabs to display data in kWh or using set currency.
The interval for storing historical energy data changed from one hour to 15 minutes.
Displaying the energy balance from the main energy meter if configured.
General
Setting the main energy meter available for devices with specified interface and rate type.
Nice*
Possibility of setting the configuration parameters.
Redesigned wizard of adding new devices.
Dedicated section in the main settings menu for Nice and Elero.
Other
Current Z-Wave engine (version 2.0) selected by default on engine selection window.
Bug fixes:
Access
Mobile devices assigned to removed users are not deleted or reassigned.
Backup
Incorrect Z-Wave engine version in uploaded local backup (ZW 3.0).
Dashboard
Rebooting the gateway results in resetting the counter of used devices.
Devices
No possibility to add custom icons after factory reset of the gateway.
In some cases, removing the device from the Z-Wave network fails (ZW 3.0).
For some devices setting the association fails (ZW 3.0).
Incorrect multichannel reports handlings (ZW 3.0).
Incorrect descriptions of parameters in Heatit Z-TRM3 device template.
Elero*
Device after binding is always assigned to default room.
Energy
Some data is not displayed when using the remote access connection.
Gateway Connection
Master gateway does not update the device states after rebooting slave gateway.
Network
Wi-Fi module is always switched on after reboot of the gateway.
In some cases, connecting to Wi-Fi network fails.
Nice*
No possibility to create and edit scene with Nice device.
Notifications
E-mail notifications for addresses containing a plus character are not sent.
Other
Z-Wave service status in Installer App is displayed incorrectly.
Translations on Yubii Home are not generic and refer to FIBARO Home Center.
Performance
Problems with gateway start-up on large systems (ZW 3.0).
Plugins
Fibaro Heat Activator plugin does not work (ZW 3.0).
Profiles
No actions available for devices (ZW 3.0).
Quick Apps
Error after updating the quick app file containing a hyphen in its name.
Save button is active even though there are no changes.
Scenes
No possibility to set scene with push notification if user with mobile device was removed.
Incorrect property set when selected the disarmed condition block.
Incorrect actions in block scenes for FIBARO Intercom.
Update
Never ending loader on devices update page when no devices to be updated (ZW 3.0).
Known issues:
Energy
The energy data collected during the use of previous beta version (5.071) is removed.
The ROI calculation functionality does not include a quantity factor.
New Z-Wave engine 3.0
Overriding the temperature set in heating schedule is not possible for FGT-001.
The schedule overwrite functionality of Z-Wave thermostats does not work properly.
Not all Z-Wave devices are fully compatible with the new version of Z-Wave engine.
In some cases, device adding/removing fails - gateway needs rebooting to retry.
Gateway connection is not available in the new Z-Wave engine version.
No support for FIBARO Heat Controller error notifications.
Elero
In some cases devices are wrongfully marked as dead (no possibility to control)**
* - does not apply to HC3L (Home Center 3 Lite)
** - does not apply to HC3 (Home Center 3) and HC3L (Home Center 3 Lite)
