Quickapp slider minimum and maximum range
Hello
I am almost done with my Quick app for panasonic heatpumps that are connected via  comfort cloud.
I hit a wall with the slider code, i really cant find any good examples
I have a value "tempe" that i send to a http server in another function
as now the device when slided all way up sets the heatpump to 65 degress or around that.
i need somehow to have range from 15 to 30 degrees and when sliding it have to step 0.5 degrees instead of now 1 degree at the time.
any suggestions how to do this.
/monthly_2021_07/image.png.3597cff6f607e6bb2b2c75c95f4a8566.png" />
Edited by mike79
11 answers to this question
9 hours ago, mike79 said:
apparently there is in the fqa file when you dl it.
changing those to
did the trick.
Just wierd there aint code for it
There is also a "step" property.
Have you tried self:updateView("slider","max","30") ?
    changing those to
    did the trick.
    Edited by mike79
    Yes that also works.
    apparently it does not have any effect in the edit window or preview mode.
    Any suggestions for stepping 0.5 at the time when changing slider values.
    Edited by mike79
    If the "step" property doesn't allow for fractions I don't think it's solvable. (haven't tested)
    The alternative is to always treat the slider as a percent slider 0-100 and present the real value in a label.
    after some investigation i got it to work
    sometime the simple is the answer.
    Edited by mike79
    Hi Mike, that would be great if it worked...
    I tested it on HC3 last FW, all updateView ended with success, but no changes at GUI and API too. Min and Max are same as before...
    It works, but not in the code editor, if you go out of editor it works
    It would be nice if we could figure out how to set the %value tip that is shown when we drag the slider, to somethings else. Now it always show 0% - 100%.
    do you mean changing the % sign to something else @jgab
    Yes, the '%' and the value should reflect the min and max too.
    not sure if you noted, this has bee changed, one can set unit property for slider
