Fibaro HC3 integration with Broadlink RM4 PRO
Guest RAJA-Easysmart
I want to know how to integrate HC3 with Broadlink RM4 PRO? If anyone created Quick apps for Broadlink devices could you please share with me the details?
13 answers to this question
I'm looking forward to this too. Hopefully there are already people here with experience.
ChristianSogaard did a very good guide for this.
I have made 2 videos on how to do this - DM me and I will send you a link
Very clear video
Thanks for the good instructions step by step
Excellent video. I am using a Harmony Hub. But this for sure would be my first choice of use.
@ppeterr The Broadlink devices are way cheaper than the Harmony HUB hence BL is my only choice :)
Thank you for the comment on the video too
@Phenix
Hi !
Thanks for the great tutorial.
everything is working fine with an RM4 PRO.
but I do have an issue that I wonder how no one is talking about.
I am trying to use this for my AC.
now at first, when i used the learning mode, I was getting a really big string for the code.
I than realized, that when i power my AC on for example, the remote doesn't send just the "turn on command"
it send a complete snapshot of the remote current settings (temperature, mode, FAN speed ETC..)
So the code that i take for power on for example, isn't just powering on...
this is true to all other commands as well..
is there any way to isolate the commands ?
Thanks,
shay.
IMHO it's as FAD for your AC,
FAD ?
@10der
I don't think it's something related to my Ac only if that's what you meant.
I think it's valid for all AC remotes that have a display.
For example,
If the current status of my AC is on heat, 28 Degrees and fan is set to HIG.
now, i turn off my AC with the remote.
I than block the IR on the remote with my hand, turn the remote on ( without turning the AC on as i block the signal) and change the remote to COOL, 22 Degrees and fan low.
I than power off the remote, point it to my AC, and click on Power ON, The AC will start on the settings as configured on the remote....
meaning, when I powered it on, it sends all the current state of the remote.
I believe that this is true to all remotes that has a screen on them.
P.S,
when pairing the RM4PRO in the Broadlink app, it asks if the remote is with or without a screen...
i guess that its for the same reason..
13 hours ago, tzimber said:
FAD ?
Functions As Designed (Developed)
On 9/23/2021 at 3:05 AM, Phenix said:
hi where can i fine the file?
