LUA | if id ne xx or xx then do
Hi
I'm trying to excude 2 id's from a bit of lua code.
could someone take a look at this and tell me if it's in the right direction?
local lightsOn = {}
local lightsf = api.get("/devices?interface=light")
for _, light in ipairs(lightsf) do
    if (light.visible == true and light.properties.state == truethen
--153,158
    if (light.id ~= 153 or light.id ~= 158 ) then -- this?
        table.insert(lightsOn, light.id)
if (next(lightsOn) ~= nilthen
    fibaro.call(lightsOn, "turnOff")
    so 2 things worked..
    1. using the right ID
    2. using AND as I knew I should.. but didn't
    this works and if you are curious as to what I want to do.. it's for the alarm. So when alarm is armed.. turn off all lights.. but not garden/outdoor lights. This is assuming it's supposed to be turned on of course.. I may add some time barrier to this.
    local lightsOn = {}
    --153,158
        if (light.id ~= 154 and light.id ~= 159 ) then -- this?
    Some Lua coding tips.
    You can combine many selectors in /devices?...
    t[#t+1]=x is twice as fast as table.insert(t,x)
    Testing for exclusion for 2 devices is ok with 'and' - testing for more use a map
    #table gets the length for an indexed array. next() is the idiom for testing key-value tables emptiness or not. #t is also about twice as fast as next(t)
    You could also look at fibaro.callGroupAction or fibaro.getDevicesID
