There is a problem with the yr weather. The scene do not start, although the condition is true and the trigger is set
For example the weather is clear, there is no reaktion , the scene doesn´t starts.
Hi @KlD8420 ,
this is HC3 forum thread, but your profile shows that you use HC2. Which is it?
    I use the HC3
    Can you upload a copy of your scene here, otherwise it will be difficult to help you.
    And please, change to HC3 in your user profile :-)
