QA | onButtonPress - highlight button
Hi
is it possible to do the following:
when button is pressed highligt the button. Mark it in blue or another color - so user can see that that button has been selected.
example:
click button A
mark button A as selected in QA
click other button - for instance Open.. play or similar.
do action
5 answers to this question
Don't know about colors, but you could always do something like
    @SmartHomeEddy - thx- That worked.
    I found this ... but it's for HC2 and doesn't work (for me) on HC3..
    can you tell if it's something that can be used?
    OK, your question was about QA so I assumed you meant quickapp.
    it is and was.
    I assume that means the above wont work in a QA?
    Text labels can be changed there are some ways to use html with them, if that answers your question.
    button and slider cannot be changed.
