bluesti 0
Hello
Have read similar posts regarding this problem, but nothing seemed clear as to a resolution. I did read that you can change a parameter #20 value to toggle, but I couldn't find it.
Pairing the Dimmer was near impossible, so used the generic Z-Wave device option and it paired as a dimmer.
Now the 4 led's turn on and off using Vera app, but I can't switch the lights on or off using the wall toggle switch and I can't even switch lights off once they're on when switched on via the app.
Do I need the bypass?
If not, can you help with a solution?
My wiring is shown in the attachment.
Thank you
John
