Dear Fibaro Users,
FYI
I have updated HC 3 with  5.072.25 (Beta).
The plugins/QA in the app works now oke.
After update with 5.072.14 plugins crashes.
Uhmmm i dont understand
current beta is 5.072.14
Do you mean you downgraded to 5.071.52 ?
Dear all
I have updated from the last stable version.
All seems to be OK
App works fine, I tested.
1 hour ago, Fireman said:
Dear Fibaro Users,
FYI
If you ask me, there is no 5.072.25 the latest is 72.14
17 minutes ago, ericl780 said:
Dear all
All seems to be OK
Good, so your on 5.072.14 (beta) now ?
Dear Fibaro Users,
FYI
In my case it was opposite - one QA re-staring in loop with error:
" ./include/main.lua:918: attempt to index a function value (field 'powerUsedHour') "
But this is simple - in latest beta 5.072.25 there is new function appeared, which have same name that I used before in variable...
Changed my variable name to other and all works good now
@ppeterr - there is new beta available from today - 5.072.25
Maybe you will get it later today or tomorrow. Try to open manually - Settings - 2. Update
@afendikov
Ahh new update :) Thanks for informing me.
Yes new update, info on forum should be soon
For the last few updates my UI has been so slow that it is (almost) useless.
Opening a tab on the device settings, selecting a text fields-radio button or similar or pushing the save button has quite a few seconds each of delay.
@tortho how much devices do you have on the gateway?
We are working on some optimizations but those will take some time.
@m.roszak 115 devices
It is the same in the android app. Opening "whole house" and then to select a room and then device you can see it loads bit by bit..
Edited by tortho
Just to be sure, tiles in interface or physical devices with generate much more tiles in interface?
Ok, only Z-Wave devices.
Thats some ;)
Thanks for clarification.
I can underscribe this too.
I have no idea when its happening but now its back after update.
If I change view I get the screen to select to close or wait. This is a long time ago I had that screen.
//Sjakie
Well, totally not sure if what i noticed is anything like the problems above.
But, when the update was finished here. The UI was also very unresponsive.
I always reboot my devices a extra time. Leave it for a couple of extra minutes so
the services are done starting  and also close the browser or app. So it clears the cache.
That helped for me.
Hello
Personally I have abominable slowness (like more than 10 seconds to open the properties of a module) if I display all the modules including those hidden in the devices
on the other hand if I only display the lights for example (about 25 modules), without the hidden modules of these, all is well
It is impossible for me to display all of them, while in the stable version this is no problem
Edited by flacon030
@torthojust try >>
check mem
backing up without history
check mem
or when its still high restore that back up
In my case it freeing up, 10% memory
Succes,
//Sjakie
well it crashes less then previews beta, the interface docent respond as slow as with previews beta, but the commands to tun on/off are way slower now
i have 110 z-wave devices connected (only version 5 and 7) running a scene takes several seconds before it start. Before my system responded directly, on the stable branch i could blink with the light many times a second, now im glad if 1 light turn on once within 3-5 seconds.
im using 5.072.25
