mioiox 5
Hi all,
I am trying to figure out if I did anything wrong when adding RGBW2 (with four single-coloured led strips) to HC3L (5.080). I followed the typical procedure and the module was added and configured successfully, as per the messages. However, now I see 5 multilevel switches that I cannot change the dimming levels of (even turning them on and off does not work quite well through browser nor iOS app). Furthermore, I recall that when I add the RDBW2 module in HC2 I was getting a pop up to select its type. In HC3L I don't get such a pop up or an option to change the type and I am not sure that the Multilevel Switch type is the one I need for LED strips.
I tried removing+adding, as well as soft reconfiguration, but nothing changes for the better.
Thanks in advance for your input!
11 answers to this question
