Gateway Connection - how to put QA on secondary controller ?
In Gateway connection there is possibility to add Z-Wave devices to secondary controller
But I can't find - how to manually add QA or PlugIn to secondary controller ?
Any ideas?
If it's not possible now - maybe it's time to add gateway selection to Add Other device interface ?
Like this, same idea that in Add Z-Wave device:
what is the reason you want to do this?
all slave devices are on master
     I want to use CPU and Memory of Slave controller for some big QA's
    It will be more balanced system - like 50/50 Z-Wave devices between Master/ Slave, also 50/50 QA's on Master/Slave
    Afaik Fibaro's master/slave solution does not allow (yet?) offloading QuickApps / scenes to slave gateways. Haven't tried if one could use API to upload them, but even if that might be possible, one is then using inoffical way which might break during updates etc.
    For such projects, i decided to intercommunicate via QuickApps/scenes to exchange only necessary information between all HC3x, without using the official master/slave solution, to have control over each of them (and in worst case to loose control over only part of the system, and not whole thing).
    But in this case you have only part devices in Yubii app and need to re-login to second controller, to control second part of devices ?
    that's right, however one can easily select the HC in the app. Sure, you will not have "turn off" things like for both HCs, unless you create on one of them QA which do the job for you on second HC.
