Rhoditis 1
Hello All,
I started using some Smart Implants on my HCL and I find them very convenient for my application : reporting air temperature, soil hygrometry and coupled to a relay starting a small pump automatically if needed.
I have some trouble with one of the SI though. I was experimenting with that one and after I unsuccessfully tried applying the latest firmware (never again) I lost almost all the SI parameters. There are just a few appearing but not the correct ones.
I did try removing the device, re-integrating it, resetting it completely, all that many times but it did not help.
The very strange thing is that it seems to work fine as I can control it and it does report correct internal and external temperature.
Is there any way I can get back its parameters ?
Many thanks
