Multi-sound siren Philio PSE02, D-link DCH-Z510
Dear Fibaro Users,
Have someone any solution to manage multisound sirene on Fibaro HC3?
I can only switch siren on/Off and not select other sounds.
Thanks.
I'm looking for the same thing.
I haven't found any solution.
You can trigger it by changing the parameters... this is the trick I do with another siren. Hope this works, only can trigger it once to play and then you need to play another.
example scene:
Ask also fibaro support to pickup to template, maybe in a next update they will support it.
