Input field for a variable in a quickapp.
Ok, so i understand the variable when creating a quickapp. (or at least, a little)
Could someone point me to, how to make it interactive, Like i have a quickapp with a
entry for a variable. I would like a dropdown option in the block scene when i use that quickapp.
With a entry field. (like a push msg does).
19 answers to this question
Maybe a global variable is more suitable for that?
    Not sure what you mean there
    I have this code
    So the variable is what i enter in the field of the quickapp itself.
    If i make it a "global variable" would it then show up as a entry field in the quickapp itself ?
    How would i do that.
    (sorry, mijn engels is zo slecht. Zeker als het wat technisch wordt)
    Edited by ppeterr
    Don’t know for sure what you want to achieve. You want to change that “saywhat”?
    A global variable can be used in a block scene:
    /monthly_2021_08/46507242-8007-4E59-B21D-33BC7296FAB2.jpeg.5506f47d788659af99bbcd963a01364c.jpeg" />
    It can also be read, created and updated from a quickapp. So maybe you can use a global variable instead of a quickapp variable.
    I created a quickapp with a variable "saywhat". So i can enter a text that will be used in a link that activates
    a TTS script so it speaks out the variable.
    I can place this quickapp-block, in a scene. So when i open the shades (another block-scene), the quickapp reads out the variable "saywhat"".
    It would be perfect, if the scene block (with the quickapp) would have a entry field for the variable "saywhat",
    so i can use it mutliple times, without changing the variable in the quickapp.
    Now i copy the quickapp, rename it, change the variable, and re-use it in a block scene.
    Tomorrow i'll look into the  global variable. Thanks for the tip :)
    I think it should work. Set the string in the global variable with the blockscene, start the quickapp and read, use the global variable.
    And maybe if the global variable is empty, use the quickapp variable content.
    I think a global variable is not what i need. If i understand it correct, a global variable is a value that
    can be set in a quickapp and used multiple times
    Sorry not to be clear enough :)  I have so many ideas but not the knowledge.
    I would like a input field, like we have in a push notification.  So you can type in the variable
    per block scene. Like the field where i typed "weg"
    No, that is not what I mean, global not like in quickapp, but global like all over your Homecenter.
    I mean the variable you can also create and edit in the "variable" tab in the "6. General" option.
    Variables may be used to expand the functionality of scenes. There are two types of variables: standard and enumerated. Standard variable takes one predefined value that can be used and changed in scenes, while enumerated variable takes one value from a set of values defined during the creation of a given variable.
    In the Lua manual:
    So it is not a "non local" variable in the quickapp (the quickapp manual also writes about global variables in a different way). It is a variable you can use throughout all your scenes and quickapps, like global on your Homecenter.
    If you use my
    quickapp, that has also options to use global variables to extent its functions.
    Edited by SmartHomeEddy
    Oke, yeah i am using your Buienradar QA. I love it, it works perfect. I took a look at the code,
    and checked the LUA manual. I decided to leave it for now. Its above my skills.
    Actually anything more then the basic stuff you can do with the HC3 has got a pretty steep learning curve.
    Or at least, for a "normal" user i think. Anyway thanks for pointing me in the right direction.
    (There are two, Buitenradar Rain and Buienradar Weather. The last one has the global variable routines.)
    It takes some time to get a grip on it. But if I see your learning curve, it won't take you much time to get this.
    Small hint:
    api.get: get the value of the variable
    api.post: create variable (with a value)
    api.put: change value of the variable
    api.delete: delete the variable
    This is the routine I use to create or update the variable in the Buienradar Weather quickapp (jgab has a better routine), tag = name of the Global and res = the value for the Global. I edited the routine from the Buitenradar Weather quickapp, to only show the basics of api.get, api.post, api.put.
    If (api.get) the global is nil, it doesn't exists, so use api.post to create and insert the value.
    If the global isn't nil, it exists, use api.put to change the value.
    No pressure ?
    @SmartHomeEddy Let me bother you one more time about this. Because i am not
    one step further. Could you please provide me with a very small quickapp, that contains
    the code for a functional global variable, that gives me a entry field when used it a block scene.
    I really would like to find it out myself, but it seems i am thinking in a totally wrong direction,
    and it its been days trying to get it to work. And it got me nowhere yet :)
    I will make a small quickapp, one moment please ...
    No pressure ?
    Kidding, no hurry at all. Thanks! I think when i see how it works, i will understand it a little faster.
    Well, this works - and it doesnt look like anything i was doing. This makes a little more sense to me :)
    Just to make it clear for me:
    So, the code makes a new variable in the api, called "globaltest"
    It stays there, doesnt do anything,  you only made a loop to show the current variable status.
    This gives me a panel, i can put in front of the block scene, that changes the variable.
    And i can use that in a next block (quickapp) that reads the api entry.
    That would be it, excellent.
    I only need to figure out how to change a local variable in the quickapp, to read the global variable.
    Thanks, thanks a lot for helping me out. Really apreciate
    Yes, it then only loops and shows the value of the global variable.
    Ofcourse you can also simply make the global variable just adding it in option “6. General” tab “Variables”
    This puts the table content of the global variable in a local variable named text
    if you want to get the value (text) of that in your local variable “say”
    Oke, i just found the option 6. General variables - feel a little stupid now :P
    You mentioned it before, so i searched the LUA manuals for option 6 ...owowoow
    This makes it much more clear for me now.....
    Oke it works, but it gives me a error. [edit] seems to be a easy fix.
    This is the QA code, that reads the globalvar
    This gives me a url, to parse to the php server:
    Where "this is a test yes yes yes " is the value from the globalvar. (yes yes this works thanks)
    When i paste this link into a browser, it does work.
    But the error is:
    Ow and that has al to do with the spaces in between
    As a space the php needs %20.
    Thats it for today :) it seems to work
    Thanks so much @SmartHomeEddy
    Edited by ppeterr
    Great to see it worked ???
    • -1
    @ppeterr Insert this code in a quickapp and let it run. At startup the quickapp will create a global variable "globalTest" if it doesn't exists. The value will be "Hello World". If the quickapp exists, the value will be updated (at startup of the quickapp). The quickapp will show the value (and table content) of the global variable every 10 seconds in the logging.
    If the global variable exitst (you can see that in the option "6. General" in the tab "Variables") you can create a simple blockscene like this:
    If you run it, the value (text) will be changed to "Dit is een test"
    The logging will look like:
    I hope this is wat you are looking for.
