I have just bought a HC3 and migranted from my HC2 two weeks ago. As the new update came out, I decided to go for Z-wave engine 3.0 and start from scratch.
After the update to Engine 3.0, my binary sensors, smart implants and door / window sensors (fgs-101) are recognised and implemented into my environment, but not triggered when I open a door, change state on IN1 or IN2. The Door / windows sensors 2 are working perfectly.
For some of the Double Switch, power ON / OFF is shown in the interface, for some it is not.
All battery devices tend to loose connection, this can be fixed with a wake-up in the interface, except for the Smoke sensor, which keeps loosing connection. When running a script, to get neighbours from the different devices, it comes back with “Device has no neighbour” on all devices…
I know Engine 3.0 is beta, but maybe this could be fixed in the very near future? Thinking of resetting and going back to Engine 2.0 as I use my HC3 for security.
Edited by JacobW
Please list here exact versions of the devices which does not work properly.
In first ZW3.0 beta focus on devices support was put mainly on currently produced devices, some older version are waiting to be fully implemented.
As for battery operated devices, we are working on it.
I am not sure what you mean by "very near future" but if this means few weeks? Nope.
Next version with some major improvements in Zwave 3.0 is planned somewhere in Q4 2021.
Michał
    Somewhere in Q4 2021 is too far away, I will go back to 2.0… Need the security to be working…
    Then I will post an exact version of devices, that don’t work, which I can’t do now, as the HC3 doesn’t recognise them properly. The door / window sensors are recognised as Binary sensors.
    But thanks for answering so fast.
    Edited by JacobW
    Z-Wave versions will be enough, it think that those devices are old zw300 modules which may not be recognized right now.
    According to Swagger:
    door / window sensors are running version 2.5
    The binary sensors 2.1
    The Smart Implant 5.2
    If I setup Binary and Smart Implant to broadcast changes in IN1 / IN2, it works…
    Ok, thanks.
    Thats give us some additional information.
    Smart Implant should work ok after setting it in the interface.
    For old UBS and FGK we need to prepare full support.
    Michał
    Perfect, I will go back to the Engine 2.0 in the meantime, if the next update won’t happen until Q4…
