thsrp 0
With a very bright light (7000 lumens) the "dimmer 2" does not lower the light very much when I am at the minimum: the brightness decrease by about 50% but not more ... ???. (parameter 1 : "minimum brightness level" is set to 1)
The light is dimmable, it accepts two protocols: "leading edge" and "trailing edge" ...
I tried with a low-end dimmer (classical dimmer not connected and bought 18 € on Amazon!) And I can lower the brightness to switching off, therefore the luminaire is perfectly dimmable.
Do you know a "workaround" to lower the brightness more?
Edited by thsrp0 answers to this question
