Two identical devices behave differently!
MikeHCam
I am currently testing two identical FGS-24s Double Relay Switches, both firmware v5.0.
They are not connected to the pumps they will control yet, so both are connected only to mains power.
I am controlling them from a Hubitat and both are being controlled by the same driver software.
I have had one for a couple of months and it is behaving perfectly (as I understand things). Using the Hubitat I can open and close both relays. To change the relay state I send the device a zwave.switchBinaryV1.switchBinarySet with the appropriate value and to the appropriate channel, and then a zwave.configurationV1.configurationGet to the same channel to update the changed state. Both relays open and close perfectly and respond with a SwitchBinaryReport encapsulated in a Multi Channel Command. Great stuff!
I received a second device yesterday and it does not behave the same. Again, using exactly the send code on the Hubitat, I send it identical zwave.switchBinaryV1.switchBinarySet and  zwave.configurationV1.configurationGet commands and again both channels switch the relays perfectly. But on channel 1 the device responds to the configurationGet command with a raw SwitchBinaryReport not encapsulated in a Multi Channel Command, whereas on channel 2 it responds with a SwitchBinaryReport encapsulated in a Multi Channel Command as I would expect, and as the older device does on both channels.
Can anyone suggest why the two devices are not behaving identically? As I have worked out what is going on (after several hours!), I have been able to circumvent it by assuming that any raw SwitchBinaryReport is always from channel 1. But that is a hacked fix rather than a solution.
According to the configuration report messages they return to the Hubitat when I ask, the parameters in the two devices are identical - see below.
Mike
The configuration as reported back to the Hubitat:
zwaveEvent ConfigurationReport Lock simultaneous switching of Q1 and Q2 outputs: 0
zwaveEvent ConfigurationReport Q2 output type: 0
zwaveEvent ConfigurationReport Q1 output type: 0
zwaveEvent ConfigurationReport S2 input – Double Click value sent to 3rd association group: 99
zwaveEvent ConfigurationReport S2 input – Switch OFF value sent to 3rd association group: 0
zwaveEvent ConfigurationReport S2 input – Switch ON value sent to 3rd association group: 255
zwaveEvent ConfigurationReport S1 input – Double Click value sent to 2nd association group: 99
zwaveEvent ConfigurationReport S1 input – Switch OFF value sent to 2nd association group: 0
zwaveEvent ConfigurationReport S1 input – Switch ON value sent to 2nd association group: 255
zwaveEvent ConfigurationReport Second channel – time parameter for delayed/auto OFF and flashing modes: 5
zwaveEvent ConfigurationReport First channel – time parameter for delayed/auto OFF and flashing modes: 5
zwaveEvent ConfigurationReport Second channel – reaction to input change in delayed auto OFF modes: 0
zwaveEvent ConfigurationReport First channel – reaction to input change in delayed auto OFF modes: 0
zwaveEvent ConfigurationReport Second channel – operating mode: 0
zwaveEvent ConfigurationReport First channel – operating mode: 0
zwaveEvent ConfigurationReport S2 input – scenes sent: 11
zwaveEvent ConfigurationReport S1 input – scenes sent: 11
zwaveEvent ConfigurationReport Alarm configuration – duration: 0
zwaveEvent ConfigurationReport Alarm configuration - 5th slot: 83820544
zwaveEvent ConfigurationReport Alarm configuration - 4th slot: 50266112
zwaveEvent ConfigurationReport Alarm configuration - 3rd slot: 33488896
zwaveEvent ConfigurationReport Alarm configuration - 2nd slot: 100597760
zwaveEvent ConfigurationReport Alarm configuration - 1st slot: 0
zwaveEvent ConfigurationReport Outputs orientation: 0
zwaveEvent ConfigurationReport Inputs orientation: 0
zwaveEvent ConfigurationReport S2 input – switch type: 0
zwaveEvent ConfigurationReport S1 input – switch type: 0
zwaveEvent ConfigurationReport Remember relays state: 1
